The polar vortex is wreaking havoc up here in northern Minnesota! It's going to be a
week of below zero weather with night time temps of 30 to 40 below F. So out of
necessity, I am insulating my generator enclosure. It's 8x12 feet so big enough but
with the floor covered with generators and "stuff" it is an interesting task. The walls
were pretty easy with fiberglass batts but the ceiling is a bit more challenging. I'm starting
with 2 inch thick pink formular (R10) and covering that with batts probably later. If the
room cools down to ambient temperature, the generators won't start. I have a 40,000BTU
Reddy heater running in there with the door open and it's comfortable enough to work.
My EU2000 Honda generator is parked outside the door a few feet to power the heater
and a trouble light. At night, I put the Honda generator in the shop that stays above freezing.
Normally around here, when it gets really cold, there is almost no wind. The forecast is for
cold AND wind so one has to be aware of wind chill. Today I get to machine 4x8 sheets of
formular to usable size pieces with a table saw...........
It's going to be insulated blue jeans today as I finish this job up.
Stay warm out there
as the cold blast will be affecting a lot of the country for a week or so it seems.
