Good Morning, It is always optimal to leave some play between mating gears. If you're talking ring and pinion, then there should be a spec called out by the manufacturer. If you're talking about lathe gears, then the optimum would be about .003-.005 of an inch. but as long as they are not "tight", it should be ok.
