- May 6, 2020
- 63
Hi there,
I need some help from experienced people in gear cutting.
I will try to rebuild my standard modern gears, they are pretty distorted, I know that I will not be able to give a good polishing to surface teeth but it just can't be worst.
I bought a cheap set of involute cutters DP16 14.5PA but looking for info I found that the smaller count of teeth for 14.5 PA is 32 without undercutting , however the cutter Nr. 1 starts to 12 teeth.
I would need a gear of 27 teeth .
I know you can't do undercutting with an involute cutter so, since the first cutter is able to cut 12 teeh, are they made to avoid interference?
