- Nov 2, 2013
- 969
A while back I purchased a set of gear cutters from a local machine shop who were no longer doing that type of work. It was one of those "impulse buys" that happens to us every now and again.. Since my goal is to (somewhere in the future) design / build an I.C. engine, I knew I would need to cut gears someday. Hence the purchase. So after getting them into the shop I've begun cleaning and cataloging what is there. But some of the info doesn't make sense to me as I've never been exposed to this yet. So I've posted below what I'm seeing and will certainly appreciate any help given/offered, from what I've learned so far (before buying all this) there are basically 8 numbered "sets" that most cutters fit into - based on a dia. pitch. Is that correct??
Here's some of what I'm seeing on my end.
first one -
Brown & Sharpe, .875" Arbor, Ang of SPI.3`( I don't see a key for degree) 30' Flipside - Jan.5-20-37.629 P.40T SPI. Gear D" + f .057"
second one-
Brown & Sharpe, 1.062" Arbor, Dec 22-16-8P.24T. D" + f .270"
third one-
R.M.Clouge Tolland CT, 1.063" Arbor, D.F. 2 / 8. p. 15-r
fourth one -
unknown oem, .875" Arbor, no data visible, 12 "teeth", can it be identified another way?
fifth one-
Brown & Sharpe, 1.0625" Arbor, Sept.17-08-10P.28 T. D" + f .216" - 22 1/2` (deg) P.A.
Last one -
GTD Athol MA, 1.0" Arbor, No2 6P BEVEL
I'm hopeful that from this grouping that I (and others) can learn what this info means, as I said earlier, any help or guidance is appreciated. TIA
first one -
second one-
third one-
fourth one -
fifth one-
Last one -
