Gasket Cutter
T
TOOLMASTER
Forum Guest
Register Today
normally a kit will run 150-300 bucks!
i picked up the block only for 15 bucks..the rest was just an hour of work
drilled out a stud for the center pin. stud made from a cut bolt
made the stud block out of 1/4" aluminum,drilled a hole on one end to store the pin
made a knob to tighten it
+ made a set of extension arms out of 1/4x3/4 stainless bar for cutting bigger circles
the main block WAS chrome plated but all worn..
i milled the groves deeper on the cutting side to 1/4 deep
and added a grove on the top side.
belt sanded off the chrome smoothed it all nice then sandblasted ..
Nice save!
Have cut a lot of gaskets with that style cutter and they work nice.
