- Oct 14, 2014
- 2,116
https://www.ebay.com/itm/0-200-Temp...567995?hash=item1c7c7bbb7b:g:VLIAAOSwOgdYnAoP
I wired this up wrong and do not understand how to do it correctly. See the attached pic. blue is +24V, white is dc common, yellow is the wire I need 0 – 10 volt for my Galil analog pickup. the value of the resistors is 1K ohm, two parallel made it 500 ohm.
I am getting 1.77 volts at room temperature, the same in the –10 freezer.
