- Apr 8, 2013
- 2,012
While swapping out change gears for a metric thread I noticed that one of the bolts on the side of the transmission was backed out a bit. It was one of the 3 bolts in the flange thru which the input shaft goes into the transmission. When I tightened the bolt, it added so much drag to the input shaft that I could hardly turn it by hand. Loosen the bolt again and it's smooth as glass. Try as I may I can't get the shaft to turn smoothly with all three bolts tight. I ended up tightening them with the short end of the allen key in my hand to limit torque. Is this flange some sort of preload (doesn't look like it) or should it be tightened town?
