- Sep 29, 2013
- 130
So I am finally getting my DRO PROS DRO installed. I was not willing to lose access to the cross slide lock screw as happens with many scale installs. This is what I did instead.
Installed the scale on the tailstock side of the cross slide. The hole in the center is for the lock screw.
The original lock screw is on the right. The replacement is on the left.
The replacement screw installed in the cross slide.
Two small blocks milled and installed as spacers.
Another view of the spacers.
Installed the magnetic scale.
View of the lock screw behind the scale.
The lock screw is easily tightened with a small 4mm wrench.
Milled and installed spacer block for read head.
Close-up of read head spacer block.
Scale and read head install complete, except for the scale cover. It's so tough to COMPLETELY finish a job!
Bob
Bob
