G4000 5C Collet Chuck - Will it Fit?
wilkerd1
Jun 2, 2022
23
Would like to get a collet chuck and collet set for my G4000 beginner lathe. Will a 5C chuck fit the G4000?
I see one on Grizzly’s site but no mention of whether it fits the 4000. Also see some on Amazon too. Since this is a starter/learning lathe I’d prefer something reasonable in price. Seems like there are a couple of good options on Amazon. Just don’t know if a 5C chuck will fit.
Thanks!
Maybe start with an ER32 collet chuck? 5C might be too big for the G4000...
Something like this...
Or get the 3C collet setup from LittleMachinShop?
Reason I mention those two options is because that is what I did with the Logan 820 and my plan was to do the same with the HF 9x20 (which is a clone of what you have).
The 5C chuck would stick out a lot... But it has been done... here is a photo of one installed on your lathe...
You will just need a backplate and the 5C chuck... just make sure you get the correct backplate. From reading the forums it seems that there were two threads throughout the years of Grizzly selling these... 1-1/2-8tpi or M39-4.0
for example, here is a 5C chuck with a 1-1/2x8tpi backplate or 5C Collet Lathe Chuck Closer With Semi-finished Adp. 1-1/2" x 8 Thread
and 5C Collet Lathe Chuck With M39 x 4 Thread Semi-finished Adapter
Get the one with the correct backplate... finish the backplate on your lathe and done!
Thank you for the info! Appreciate it!
Starting with that ER32 adapter seems like a good, cost effective idea to get going with collets.
Dumb question here…does using the ER32 adapter block being able to chuck longer work pieces through the lathe spindle?
No. You are only limited by the 7/8" ( I think) spindle bore...
But price wise, I think either option will run about the same... so go with the one you would like the most...
My 5C collet chuck is 5" in diameter so size wise, you are good. As previously mentioned, you will need a back plate. As I recall, the spindle thread on the G4000 is a weird size (M39-4 ) so you will most likely have to do your own threading of the plate. No plug & play. The lathe doesn't list a 4mm pitch but if I did the math correctly, Using QCGB lever in position 1, an 80 tooth gear for the "a" gear, and a 30 tooth gear for the "b"gear, you should get a 4mm thread pitch.
...As I recall, the spindle thread on the G4000 is a weird size (M39-4 ) so you will most likely have to do your own threading of the plate. No plug & play. ...
FYI - I was able to find those... so, thankfully, no need to do our own threading for the backplate. The links I provided had the chuck with the correct backplate for M39-4.0
Sometime in the 1990s, Grizzly changed vendors. The earlier model was G-1550, which is what I have. When they changed over, the new part number was G-4000. They are essentially the same machine, the G-1550 having a 1-1/2X8 TPI spindle nose and the G-4000 having the M39X4. There are some minor differences, fasteners being Imperial versus Metric, things of that nature. That and the source, the G-1550 being made in Taiwan and the G-4000 made in Mainland China.
Found the comment on the changes in threads for these lathes...
