G0752 Mounting Holes
CPCaballero
Sep 8, 2013
9
Would someone with a G0752 kindly post the mounting hole pattern with dimensions? I have a 48x19-inch workbench and I want to be sure the holes I would drill in the top to secure the lathe would clear the frame.
Thanks!
Thanks!
This should be the same pattern as the G0602. There are two mounting holes, one in the headstock and another in the tailstock. I measured the distance at 32-5/8" on the exit end of the 1/2" mounting bolts. The tailstock hole is about 5-3/4" from the right edge of the chip tray and the holes a fairly close to directly under the spindle centerline. I used the chip tray as a pattern and drilled the holes from that. I made my table from steel and the lathe rests on a piece of 7" steel channel with a skin of 18 ga. sheet steel over it. Here is a shot from the manual.
Bob
