G0704 parts
kd4gij
Feb 7, 2011
5,039
I was given a Bridgeport type power feed that I want to use to for z axes on my G0704. If anyone that converted there mill to CNC and removed the crank assembly I would like to buy the housing and shaft. I need to make a shaft and mounting. But need mine intact to do that. Thanks for looking
The Parts are fairly inexpensive directly from Grizzly. For example the shaft is $7.75. You might consider purchasing it directly from them.
Part#'s 41 to 47
I priced the parts through grizzly about 90.00 shipped for every thing. I have read a lot of conversion threads where the parts are removed. If I luck out I will just buy the shaft and take mine apart a dozen times to make it.
