I'm trying to find the easiest (of course!) way to make a square toothed gear.
There was a post earlier with a killer link to a site that made EXACTLY what I wanted:
As you can see, I could design it, print it, cut it out and try it even!
(it's a timing wheel for my twist on the $25 tach BTW!)
I suck at autoCAD though, which is the only other way I could think of doing it - no way I'm going to free hand that and hope to get it right!
I can run a DXF or whatever through CamBAM etc and generate the g-code.
There's 36 teeth, 100mm OD, and a 55mm center hole.
Any other ideas? I'm going to need to do at least one more, since I'm taching my drill press too (why not eh?!).
