- Apr 7, 2018
- 143
I have struggled with the tailstock alignment on my PM1030 for two years. While I have not done any turning between centers, alignment is needed for drilling as well. and is done frequently. I understand the methods to true it up. The problem, for me, is the design of the adjustment mechanism. You need both vertical and horizontal axial alignment. And the alignment needs to maintained as you run the tailstock quill in and out. The tailstock is a two piece affair, a bottom piece that rides in the bed and a top piece that has the quill. There is a holddown bolt that runs vertically through both pieces to a block steel below the bed to secure the tailstock location. There is no adjustment for vertical alignment, other than shims between the two pieces. The horizontal alignment is done with opposing screws with a small set screw. to "fix" the location. After a couple frustration days trying to get a nonn-tapers turn, I put a test indicator to measure the vertical deviation and dial indicator on a ground test bar to measure the horizonal deviation at the same time. I found that the the vertical alignment was ~0.005" out. I adjusted this with shims between the two tailstock haves. That was easy. The real issue is the fact that the hoorizontal alignment is affected by the opposing screws, the set screw and the holddown bolt. The tension from the holddown bolt tends to distort the alignment is no repeatable ways. The tension on the set screw also modifies the alignment, but in a more predictable manner. Note that the bed itself has been aligned to within 0.0005".
How is this done on other brand/models of lathes?
Comments, admonishments, suggestions welcome.
