I tried to engage the back gears on my logan yesterday, and found the cone pulley is completely frozen. I removed the set screws and filled it up with PB blaster and let it sit. I got it to budge maybe 1/16 of a rotation, but not any more.
To hold the pulley still, I stuck a steel shank into one of the oil holes and used leverage against the side of the headstock. I also tried a pipe wrench on the gear of the cone pulley. That did exactly what you think it did. :angry: The shank worked the best, but eventually bent and snapped. No damage to the set screw threads.
Does anyone have any tricks for holding the pulley still while trying to turn the spindle? If not, I'm thinking I can remove the chuck, unscrew the bearing cap, then use a slide hammer to try to pull the spindle out. Once the pulley is off, I can replace the bushings (or the whole pulley) and clean up the spindle easily.
