Free up a very stiff Bridgeport Series 1 Ram
dansawyer
Jun 13, 2018
450
The Ram on my Bridgeport Series 1 (BOSS CNC) is very stiff. It will move, but with all the force I can muster on a 9 inch shaft. I have read about a pincing mechanism front and rear. The advice seems to be remove the 2 locking nuts and liberally spray penetrating oil in the two holes and the front and rear along the 'ways'.
Is this the best advice?
Is it missing anything?
Thanks in advance. Dan
has it been working ok and then tightened up on you?
I just got the mill about 2 months ago. I have only tried to move it about 3 times, there is no change. It moves but is very very stiff.
the quill lock isn't on is it letter L
I may have used the wrong term. It is the machanism that sits on the top of the column and moves the head assembly front to back. It is held in place by two botls and moved by a lever in the middle. It is not a precision movement. It is usually locked in place so I understand it it common to freeze up. There is somekind of pincer mechanism that apparently gets stiff.
Mine was stuck fast. I used a small hydraulic ram between the columns and head, which freed it enough to start it moving. It didn't take much, just more than you could reasonably expect of the little rack and pinion. You could easily pull it backwards with a ratchet strap too. I came to the conclusion that it was simply gummed up with old oil which had turned to thick sticky grease on large working surfaces.
Plenty of penetrating fluid, cleaning and working it won the day. Try tapping the heads of the lock bolts lightly too, but he wary of removing them completely - they're a swine to get back in.
I guarantee that leaving it unlocked and trying a Y axis climb cut will result in it moving quite freely, though!!!
Clean and lube
i also had to uses a jack to move it
rust/dirt Lakshmi of use
A good secret sauce is a 50/50 mix of automatic transmission fluid and acetone. Apply and allow to soak for a few days. You can also use the old standby liquid wrench but I think the sauce works a bit better
The acetone may be hard on paint so beware of putting it where you don't want it
-Mark
Yes, I am familiar with that mixture. I started using it about 30 rears ago. I would run an auto engine up to temperature, turn it off, and pour 2 cups into the oil. I would then let it sit overnight and run the engine 20 to 30 miles and then change the oil. This did wonders for cleaning out gunk and carbon.
I think that mixture actually used kerosene instead of acetone but yes it does work
-Mark
