- Sep 16, 2014
- 6
Morning,
I found something,a dividing head calculator even I can use.I love this thing,I hope it can help others,you ad you divisions you want and highlights the common plate holes you can use and you can add hole if you have an odd plate like mine BUT will only lock in the amount of holes that can be used for the division you have entered.The instructions are on the right hand side of the sheet where you will find the password "OPEN" all in caps to add other hole if need be(which I had to) and hit enter,if it does not highlight and calculate,the specific amount of holes you entered cannot be used,,,,self explanatory really,,,hope this helps somebody else in the same boat.
Regards
Anthony
View attachment dividing head calculator 40 to 1 ratio.xls
Regards
Anthony
