Forward / Reverse Lever for South Bend Heavy 10 ?
Don T
Jun 1, 2020
45
I am missing this lever and gears on my Heavy 10. How do I know which one (Gear size) is right for mine? The gears are different on each? Thanks
This is my banjo gears if that helps
There is a chart in Machinery's Handbook if you need to determine the diametral pitch of the gears. It is quite handy to
determine tooth size is that is what you need.
Edit.... it helps if I read the whole post.
You will need that assembly. If it comes with the removable gear, that's even better. Mine typically has a 16 tooth on it for regular turning.
The pitch on the removable gear is 16, while the three gears that aren't removable are 18 pitch. The removable gear is the stud gear on the change gears.
Do you have a quick change gear box, or is it all change gears?
joe
By the South Bend parts manual, all of the major components of the reversing tumbler are unique to the Heavy 10.
joe
Yes I have the QCGB in this pic. So the main thing is that gear on each in the pics that is different sized changes thread pitch. Thanks I am still learning about my lathe. I got it for free and it was missing parts so I am just trying to get what it needs
This is the gear box I bought (It fits fine) I grabbed it because it has the banjo gears also and I needed them to.
Any chance you could post a link to that chart? Thanks
The heavy 10 used 16 pitch for all change gears, including the input shaft for the lead screw/ gear box, and the outboard gear on the two-gears-on-one-shaft on the reverse mechanism. The other gears on the reversing mechanism and the spindle are 18 pitch. I'll try to grab a photo if I can and identify which is which.
joe
I threw together another thread to talk about how things work for both reversing mechanisms, and diametral pitches. You can see that over here if you are interested, but I'll summarize that here.
The basic formula is the number of teeth on the gear plus two, and divide the resulting number by the diameter of the gear in inches. As an example, my south bend "junior" had a 16-tooth gear on the stud for regular turning. That gear was 1.125" in diameter. It means that 16 teeth, plus two (which is 18), divided by 1.125, comes out to "16". A 32 tooth gear had the diameter of 2.125", which means (32 + 2) / 2.125 = 16.
"A" is the spindle gear, "B" is the reversing mechanisms, "C" is the stud gear for threading using change gears, "D" is the idler", and "E" is the screw gear. "C", "D", and "E" are easily swappable for threading. The others are not. These three gears are all going to be the same gear pitch, which is 16 on mine. "A" and "B" have to be the same gear pitch as each other as well, but those are 18 pitch. What is inside the gear box, I'm not sure, but they all need to be the same pitch as each other as well.
Hopefully, this helps.
