I am a newbie. Have been enjoying my new PM1030. Tried the follower rest on 15" of 1/2" steel rod. 5" in the chuck.
Adjusted the top and back brass slidey thingies (sorry, just don't know the right word) so that they touched the top and back of the rod. And I took a skim pass. Seemed to work well. Went back for another pass. Well, after a few passes it dawned on me that the slidey thingies needed to be slid (down and in respectively) as I no longer had a half inch rod--maybe only a .48" rod.
I am missing two key ideas on how to use a follower rest:
1) Do you have to readjust them after every pass? (Seems like a pain, but seems to be needed)
2) At the end of the pass (when the tool is closer to the chuck) and after a few passes the brass slidey thingies are no longer on where you have machined the diameter down. How are they supposed to "ride-up" to the original diameter?
This is clear as mud. But maybe it is a standard problem and the experienced hands here will recognize my confusion. If not I can post a photo.
Thank you.
-Bill
Thank you.
-Bill
