I'm pretty sure that a springy follow rest isn't going to do him any good. If he sets the follower spring to exactly balance the cutting force from the tool at one diameter, it will be either too big or too small a force at other diameters. I'm not sure how I'd do the long taper he is trying. He might be able to get away with doing an inch at a time starting at the outboard end and with a fixed rest riding on the full diameter of the initial bar. The problem there, of course, would be matching up the various one inch pieces. Depending on his tolerances, some gentle filing might be enough to blend the various pieces together.
