Fly Cutters are cool
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,666
All I have is a small 1/4” shank import fly cutter.
I’ve seen the finish that can be achieved by a properly made tool.
I finished this today. It works beautifully!
This is a 5/8” shank insert holder. This appealed to me for two reasons.
Changing an insert is quick, cheap and easy. I also wanted some stability for this size of cutter.
If you haven’t made one, put it on your to do list.
I certainly see the appeal of an insert, but HSS is far better at getting a good finish with very small depth of cuts. Anyway my fly cutter uses an HSS bit and has a six inch swing. It works great at removing just a thou or two with a finish as smooth as glass.
Not necessarily. It all depends on nose radius, although I can see where HSS has the advantage there.
@Janderso Hey Jeff, where did you purchase the carbide cutter from? I already have a couple of fly cutter bodies but looking for insert cutters.
Same thing @MrWhoopee. Could you provide a link as to where you purchased yours? I have a bunch of CCMT tooling, and it would be nice to utilize the "free" edge.
I have some 5/8” HSS blanks. I plan on grinding a left hand profile to give me options with this tool.
