In the never ending task of trying to get the most out of my CNC mill I decided to set up Mach3 to control my flood coolant pump. I've configured Mach3 and my PMDX-126 BoB so that the KM1 relay is operated by Pin 1. This all seems to work fine. When I press the "Flood" button or enter a M8 command in Mach3 Pin 1 becomes active and sends a 5VDC signal to my SSR. I confirmed that I'm getting 3.95VDC at the SSR and the red indicator light does come on. The problem I'm having is the pump is not starting. I must have a mental block because I'm not understanding what's going on with the AC side of the circuit. Whether the SSR is activated, or not, I'm reading 120VAC across the SSR AC terminals. When I check continuity across these terminals I get nothing when the SSR is activated.
Here is a schematic of my wiring. Like I said I'm just not seeing what I'm doing wrong.
