I use dark sulfur cutting oil in a pressurized flush system for chambering rifle barrels.
The clear PVC tubing sold at the big box stores (both reinforced for pressure applications, and the plain stuff) eventually gets hard and brittle from the petroleum.
Cheap enough to replace periodically (which I've been doing) but now I want to find suitable tubing that's compatible with this application.
McMaster lists the semi-clear yellow Tygon as suitable for "intermittent" use with petroleum based products. What the hell does that mean?
Intermittently with other than petroleum based products, or periodic (as opposed to constant) flow? There will obviously always be residue of the oil in the lines even when not in use.
I prefer to have some visibility of flow which the Tygon allows (and it'll handle the 40 psi pressure), is this suitable- or should I just use the Buna-N rubber that's opaque?
