- Feb 28, 2019
- 530
OK - there are no stupid questions....
I just got a SMW fixture plate to go with my new 770M. Based on my prior limited experience, it looks awesome and will really help with fixturing.
Q: How do you pop out the plastic plugs on a mounted plate?
I get why you would want to cover the holes that are aren't used and also mark some holes with different colors etc.
All I'm asking is how do you personally pop the plugs out when you need to use the hole? I've put a few in and can't pop them out without digging in with a screw driver or knife or something to lever them up from the top (seems like a bad idea as could easily damage the top of the plate and mess up the use of pins etc). And only pushing them out from the bottom is a non-starter if you have to take the plate off every time you need to use different holes.
Is there some obvious trick that I'm missing?
Like I said, feels like a dumb question but I can't think of any other way to remove the plugs when I want to from the top.
