good two piece approach to the lead screw bearing replacement
Hi,
I was pleased to find your description of the lead screw bearing repair. Years ago, I cobbled together a "pinned" sleeve for my Atlas Craftsman 12 X 36 lathe (3/4 inch lead screw). I shared the idea on a forum, and the gentleman whose site you referenced picked up on the idea and posted it! At that time, I had used a bent piece of aluminum to hold the bronze bushing, and had to put some shims behind the aluminum to get it to locate properly. I used a pop rivet to hold the sleeve in position.
Anyway...recently, I've gotten back to using the lathe, and also added a Grizzly G0704 mill to my equipment. With mill in hand, and some aluminum stock that had been bored for a 3/4 inch bronze bushing, I set to work to make a new one.
The key feature that I used (that was not described in the reference) was that the 3/4 inch bushing (with an o.d. of 1 inch) actually had a second 1/2 inch i.d. bronze bushing pressed into it.
I used that same feature again with the new housing I made (just today). So, the bushings are a slip fit in the aluminum block housing, and are held in place by a pin (this time, I used a clipped aluminum nail that I had on hand rather than a rivet. Again, the nail/rivet is inserted in a hole through the housing and into the 3/4 inch bushing (actually, I used two sections of 3/4 inch bushing, with one 1/2 inch bushing inside of them both).
The benefit was that I didn't have to turn down that pinned washer at the end of the lead screw.
This fabrication is much more stable than the last one, and has better alignment. But I used the lathe a fair amount after the first repair.
I trust you'll have good success with your design as well.
Thanks for sharing,
delkeen
