Fixing A Transfer Punch or Transferring it to the trash
Pmedic828
Feb 19, 2013
220
I thought that I had posted this yesterday, but could not find it in any listings. Anyway.... I purchased a horrible freight transfer punch about a year ago when 1st getting my machine. Needing so many things and not knowing where to purchase things, I thought that I would purchase a cheap set of transfer punches. However, after using these punches for 3 separate times and flattening the little point on these punches after 1 hit on 3 different punches, I think that I purchased lead punches instead.
As the points flatten, they will not make an index mark on the steel and looking at the end of the punch, they now resemble pin punches with distortion on the tip -
Could I mount these punches, drill an appropriate hole in them and cut a piece of drill bit or HSS rod, grind a point on them, and then use locktite to secure them in the punch bodies - is this a good idea :pondering::pondering: or will it not work. :anyone:
Try recutting the tips and heat treating. Bring to a full red and quench. Temper if you want
Take them back for a new set, Harbor Freight claims to have a lifetime warranty on hand tools. Maybe the next set will have better heat treatment.
Agreed.
Unless you were using a 20pound maul to set the hole.
Daryl
MN
I think I would go buy a good set of transfer punches, and use the HF junk for pin punches or something. I have a couple of sets of HF transfer punches, but mine seem to work OK. I probably bought them about 10 or so years ago, and don't use them that much and then mostly in aluminum.
I also have this HF set that I purchased back when I was a mechanic. I've been wanting a quality set but the HF ones have been holding up fine for me. I use them on aluminum, brass, mild steel, & cast iron, haven't flattened one of the pojnts yet but then again I don't bang on them hard. If I need a deeper center punch (rarely do) I use a dedicated center punch.
I have a set of those cheap HF transfer punches and they work fine. I don't hit them too hard. Use them to mark the spot and use a center punch if I need a bigger divot. :dunno:
Mark Frazier
I have a set from HF and a set from Enco. The HF set seems to be somewhat inferior to the Enco set, but neither of them is fancy by any means. A few of the punches in the HF set have dulled, but I always try to use that set first. I figure they can be used as pin punches once the tips are shot, as somebody else mentioned already.
As already mentioned, transfer punches are only meant to transfer a light mark, more like a prickpunch. You then enlarge the mark with a regular center punch.
Some of the punches in my set haven't flattened a bit whereas others flattened with little more than a tap with a small hammer on mild steel. That leads me to believe their tempering process is hit or miss at best. I've gotten bits and pieces and a number of multiples in some sizes at yard sales and auctions, most of which seem to be of very good quality. Of course a few are trashed.
I have the HF set and have used them mostly on aluminum. As mentioned above some of the punches are fine and other flatten with only a light tap. I am hoping Santa brings a nice set for Christmas!
