- Apr 13, 2014
- 12
I noticed that my bearing support, 10F-16, was cracked and I removed it for repair. Surprise, it melted when I tried to weld it! I felt real bad and looked and hoped for a replacement. I was glad to see that they were available, but a little pricey. So I decided to try to make one myself, it is not a highly stressed part and I had nothing to lose.
I cut the bearing housing off of the bracket and turned it down from a football shape to a cylinder. Then I made an aluminum ell bracket and attached it to the lathe. I put the bearing cylinder on the leadscrew and operated everything to find it's center. Then all I had to do was to pot the bearing cylinder into the ell bracket with JB Weld while everything stayed in place. This somewhat retains the stock look and uses the original bearing for its purpose. I hope the pictures explain it better than I did.
I love my lathe.
JD
I love my lathe.
JD
