- Oct 16, 2019
- 6,876
I had a few minutes today so I tried my hand at single point threading.
I wanted everything to happen slowly so I put the lathe in back gear and chose 10 TPI so I could see what was going on.
Had a spare piece of aluminum of no particular diameter and went for it.
Turned out spot on according to my thread checker.
The finish is crap because it was low speed on aluminum but I am quite thrilled because I didn’t crash and hit the mark on the thread dial every time.
I’m not sure why the first couple of threads look so crummy when the balance look semi-ok.
I got a bit muddled when I didn’t count my turns back out on the cross slide so I just went to the end and put the tool against the work and reset to zero and backed out again.
