- Sep 7, 2020
- 111
Been using a little Emco-Maier Compact 5 for the odd times I needed a lathe to do something, which honestly was small work and the Compact 5 did all I needed to do. I guess I have had it maybe 15 years or so, most of the time of which it has just been getting dusty. But recently I wanted to do a few things to spruce up the shop press I bought, and found that the Compact 5 choked on what I tried to get it to do. So recently I decided I just wanted to get something a bit bigger, but odds are I won't really need anything MUCH bigger.
So I noticed some Chinesium lathes being offered at reasonable prices that seemed to have pretty decent on-paper specs. 1.5" through the spindle, 1.5 horsepower motor, 8.7"x 23.6" bed, and the usual extra gears AND a steady rest and follow rest. Actually bigger than I really need, but probably not TOO big. Oh yeah, it only weighs 160 lbs soaking wet, so my wife and I can manhandle it into place without killing ourselves. We are both getting up there in age, so I'm not keen on over estimating mine and her's failing strength. I will probably remove most of what I can before we do most of the moving anyway, so that will help even more.
Watched a lot of videos and read accounts of what to expect with a new Chinese lathe. So I expect I will be taking it apart and cleaning everything, checking for burrs and machine marks, and possibly touching up any sliding surfaces with find grit stones to smooth them out. May just go ahead and replace the spindle bearings right away, since that seems to be what most people recommend.
So my question is, what should I look for that could be a problem that would mean just rejecting the lathe completely as being unacceptable? Things that would mean that even for my limited requirements of tolerances and accuracy would mean a brick wall for realistic use? Things I should check BEFORE taking it apart, and things I should look for WHEN taking it apart.
I plan on buying some accessories as needed if the machine passes muster. But honestly, if I use this even a couple of dozen times before I kick the bucket, I'll be surprised. But I sure do like HAVING tools......
Appreciate any advice. But please don't waste your time trying to convince me I should get a larger lathe. They are all too big for where I want to put it, and too heavy for me to be able to handle. This one I selected is just about at the top of the upper limits anyway.
