First thing I made on my Mini Lathe
paul_cpu
Aug 3, 2020
103
I have a Hobby rock tumbler. It ran well for a few months then I came outside to an odd sound. I saw the tumbler stopped "tumbling". I pulled it apart and saw 2 plastic gears worm and slipping and that bush on the drive shaft of the electric motor worn badly and allowing a lot of play. The photo shows the size. I had a look on ebay for a replacement motor ( I mean the tumbler was $30 second hand ) a motor was a few dollars. After some consideration I was wondering if I could get my dad to make that bush. He does have a lathe but he is a bit older and with this COVID stuff I can't get over there easily. I decided to start checking our some Lathes and pulled the trigger on a Mini lathe.
Hi Paul,
I'm hoping for an update of your lathe, and your fix!
-brino
And so it starts . . . Congrats!
Bruce
Old and new.
When I bought the lathe I also bought a cut off blade. I didn't know I had to also buy a holder for that so I cut it off wiht a hacksaw and filed it down to the right width.
Nice use for the mini lathe. Right inside the work envelope.
One of the Drive geas was totally worn. The exact outgear seems to be hard to get ( I did order a bunch of random gears though they have not yet arrived ). I needed to fix this. The inner gear is pretty standard.
I had this little one and figured I could carefully file off the stuffed inner gear off the old one file the teeth on the new smaller one, perfectly align them and glue it on. I roughed up both faces and used some B600 glue.
It's drying now. Ill ensure there is no debri in the hole ( incase some glue leaked in ) and see how this goes. I test fitted and there is sufficient clearance even with the new gear glued on the old one.
