- Oct 17, 2022
- 8
Probably not a big deal to some of the more seasoned veterans, but I have been wanting to try my hand at turning a precision taper between centers. I needed a 3MT center spindle for my rotary table for a 1911 checkering fixture I have been working on, so I looked up the specs. The biggest hurdle I had to overcome was figuring out how to offset the tailstock the correct amount. I have watched a couple of videos on the process, but all of them required one item or another that I didn't have, so I had to come up with something that would work for me. Ultimately, I cut a bar 10.25" long, and then took the taper per inch and multiplied that by 10. I kind of swagged the numbers because I had no way to accurately measure how far my centers protruded into the center drilled holes, or maybe I was just too lazy to try. In the end, I just called it 1/8" on each end, effectively shortening the distance between centers to 10". That made for some easy math, so I set up a dial indicator and offset the tailstock 0.250 inches, and started turning. I stopped about half way thru, and did a test fit, and it dropped in with a nice plunk, and locked up tight. I managed to knock it back out, hit it with some color and spun it in the bore, and if the contact pattern wasn't perfect, it wasn't far from it. Went ahead and set it back between centers and cut it to the final dimension, re-checked the fit, and called it good.
All things considered, I learned a lot in the process, probably the most important is that it isn't some black magic, but a systematic approach to designing a process that gets you where you need to be. I could have run out and bought some more insturmentation, and I am sure I will in the future, but there was a certain satisfaction from coming up with a plan that made due with what I had.
