- Jan 14, 2012
- 56
I've been working (as time permits) on my first lathe project - adding a bearing to my compound slide handle (I have Micromark 7x16) for my lathe. I'm using the plans from
http://aardvark.co.nz/pjet/lathefix.htm
The only differences are dimensional. On the cited web site, his compound slide shaft diameter is 10 mm. Mine is 12mm. I ordered a 28 mm OD by 12 mm ID by 8 mm wide bearing from McMaster-Carr and a 12 mm drill bit from them. They arrived quickly.
That's the only thing metric about my bearing housing. My lathe wheels are in inches, so I've been taking all my measurements accordingly.
I have a basic question about boring. My bearing fits well into the housing I've made, but I'd been eyeballing it and taking little cuts to get her where she needs to be. I tried to do some math and use the graduations on the wheel but wasn't having much luck. My boring bar is lined up perpendicular to the cross slide, so I believe my .001" graduations on the compound wheel are truly .001". Is this correct?
Another question concerns the graduations as a whole. If I'm at, for example, an inside diameter of .232 and I need to bore out to .314 than
I would turn my wheel almost 9 graduations, is this correct?
Or if I have to make a .156" deeper cut from one depth to a deeper depth, that would be 156 graduated turns, is this correct?
I don't want to eyeball stuff - I want to do it the right way. As you can already see, I don't have an DRO's on this machine.
Thanks. In case anyone is interested I'll post my progress and add some pictures.
