- Jan 23, 2012
- 1,216
i have completed the brackets for thecraftsman 12 lathe that i have. Theguard is the only thing I am lacking. Maybe because the reader is actually hiding behind the cross feed casting,it will not be required if a person is a bit careful with the swarf and fluids.
I may use mine the way it is and justbe very careful. . . . possibly its not a problem after all. Ive seen a few applications where they areright out in the open, laying flat.
on this installation, I have securedthe reader to the cross feed and attached both ends of the bar to the bed. This means the wiring to the head must movefreely. there may be a way to mount itjust opposite. I think a lot ofbracketry would be required. Anyonewant to think outside the box here ?
the attached pictures show the mount/ mounts (I made 6) that will require some additional tweaking with a file ordie grinder, and of course some paint to pretty it up. They’re crude but functional.
I am certain I will never need thetotal length of the lathe for turning anything as my machining is usuallylimited to fixing small stuff. . .
next I wll figure out a cross feedmount for a 6” dro . Being it’s a 12”lathe, I can’t see a need for over half the max diameter of it. Please correct me if im wrong.
Questions ?
Questions ?
