Made my first machinist jack. My plan was to make a a set that worked kinda like a starrett where they stack. Went fairly well but I have a couple questions.
I also need to get some bottoming taps.
When plunging in the end of the part to make a relief, what is the correct procedure or tool? I had the best luck with a boring bar but I don't believe it's correct.
How much pressure should I put on the knurling tool?
Sent from my SM-G960U using Tapatalk
