- Dec 5, 2017
- 467
Got some tooling in for the Grizzly 7x12 lathe today so I finally got to play with it a bit. Anytime Tools 5 piece 1/4" indexable cutter set, center drills from the same outfit and a Nova MT2 1/2 drill chuck.
Turned some steel round stock down from .325 to .310 to make it fit a dial indicator stand I had. Once I got the speed dialed in and used the auto feed, it cut a REAL nice smooth finish.
Had to make a couple of bearing spacers for the ATV I'm helping a neighbor kid rebuild/repair. The old bearings were .340 wider than the new OEM bearings. Happened to have a piece of pipe the right OD and ID, just needed to cut pieces .340 wide. Haven't gotten my parting tool in yet so whacked them off to rough size on the chop saw and then faced them down to finish size, which also ensured the faces were square with the bore. Worked slick.
Slipped the Morse Taper drill chuck into the tail stock, chucked up a center drill and bored a hole in the end of a bolt just for practice. Dead-nuts center within the margin of error of my measuring equipment. That's gonna make cross-drilling pins for grease zerks a snap.
The inexpensive cutters worked better than I expected. Once I got 'em shimmed up on the centerline, they cut nice with no chatter. Not gonna make any big hogging cuts with them, but most of the stuff I'll be fooling with won't need 'em anyway and hey, I'm retired. Time, I got.
