- Nov 9, 2017
- 222
Hello All - I'm about to set up to start trying to produce the part shown below. I have a plate of aluminum about 12mm thick and 10-15mm larger in x and y dimensions than is necessary. My milling machine is manual, as is my lathe.
First question - to accurately drill/tap these holes in the correct positions I think I can just carefully move the right distances in X and Y. Is there a better way? I'm new to this and my tooling isn't built up substantially yet, don't have a swivel base for my vise etc.
Second question - is there any way with a manual machine I can produce the radiuses on the corners? I presume I'll make the entire part on the mill.
Nothing has to be super accurate in dimensions (+/- a mm for most aspects) except for the hole locations, because bolts will go through them into already made blind holes on the part this bolts to.
Thanks for any advice.
