- Mar 3, 2020
- 195
Hi, I am looking for my first boring bar and evaluating options. Lathe is a Logan 200, 10" swing.
First the material... any concerns running carbide on a lathe with top speed of 1450 RPM? Most of my bores are likely 1/4" to 1.5" range, but might have occasional needs to go larger.
Then to pick a manufacturer: (tool and any inserts must be USA made)
- Micro100 - solid carbide - looks nice, but seem to be consumable in the long run without inserts?
- UltraDex with inserts - look nice, pricey.
- Ajax bars with inserts - I can't actually tell that they are American made - I don't see it listed. Anyone know? e.g. https://www.ajaxtoolsupply.com/ajst06inboba.html
- Other brands / options I may be missing?
- Looks like I'll need a bar fairly small relative to the bore size if I want to turn the bottom of the bore flat, given the bar diameter plus the offset of the cutting edge or insert face beyond the outside diameter of the bar.
- Am considering 3* or 5* lead angles, not sure if one is substantially better than the other, or something else?
- My only boring bar holder is an old Armstrong holder for a lantern tool post (I don't have a QC tool post), but I think I can make this work or build another holder as needed.
