- Feb 28, 2019
- 511
Below are some images of the model/design I put together for an attempt at a windup gearbox. It does nothing other than prove that I can build this sort of thing.
The flywheel will allow me to get a sense of how much force the geared down spring can provide.
Two 12:1 gear sets in a row, the final flywheel will spin at 144 X the mainspring unwind. The gears are rather large for the assembly - at this point the smallest cutters I have are M1. If this goes well I'm going to probably get a set of 48DP cutters.
Regarding the gears, I know that a 6 tooth pinion is really pushing it. I looked at a number of approaches to the pinion gears, including pinion wire ($$!). My conclusion was that I'd try to do it on my desktop CNC first. If I can make decent small tooth count pinions with the CNC it will provide a lot more design freedom for future projects.
The model doesn't have any shafts in it yet. I have not put a lot of thought into that. I don't have a great sense of how hefty they need to be or how to handle the bearing interfaces. From the research that I did do, I picked up two tips - first that the shoulders of the shafts should be relieved to reduce friction on the frames and also that (at least for clock work) the pinion holes in the frame should have a slight taper. The tapper allows for reaming to a precise fit and also provides minimal surface contact on the pinion.
The plan is to start cutting gears today.
Any thoughts or tips on the gear train etc. greatly appreciated. Again, the primary point of this project (at this stage) is to learn and prove I can do it!
-Dave
-Dave
