- Oct 11, 2019
- 139
well I finished the SAW-blade attachment thingamajig for degree setting of the chuck and spindle on the Logan lathe today
but I still haven't finished the degree WHEEL yet.....
I caught myself on fire and burnt a 4" hole in my light jacket too !
I was grinding a slot in the 1/4" thick bracket so the bolt would clear and saw a bunch of smoke out of the corner of my eye
it was ME !!!! i was burning ! LOL so I swatted it out and got some of the melting cloth on my hand...that smarted !
and here I thought it was a wool jacket....guess not ! oh well !it wasn't long for the world anyway LOL....
the burn didn't go through my T shirt so it wasn't bad at all... just a comical annoyance ! HAHAHAHAH
... but I stood to the side and continued the grind and got that done.... put the bracket for the vice grips on the bracket for the lathe and then the vice grips on the little bracket and tried it out.... it works great , although it is a bit lower than I like but it will do just fine for what I have in mind.
when it is clamped on the saw blade the thing is solid throughout no movement of the spindle either way...
although setting it to the exact scribed line is a bit tedious once it is set it cannot move in any way shape or form !
so, I'm calling that part done .... I'll use it to drill the many holes in the flat pulley I have prepared for the degree wheel then I will take the vice grips Off the bracket
and make a faster Pin type arrangement for selecting the holes I want. ... then it will be completely done...
i haven't started myself on fire in at least 10 years ! last time it was cutting metal with the arc welder blowing it apart so to speak.... best not to sit when doing that !
got a big glob or red hot metal on my pants ! that one hurt ! LOL...... you can get up real fast when hot metal persuades you to do so !
later All !
hope you didn't catch yourself on fire today ! HAHAHAHAHAHA
Bob........
later All !
Bob........
