U
umahunter
Forum Guest
Register Today
Ok tell me if I'm thinking correctly say I want to find quick center on a say 3/4 small rod. if I put that rod in a 5c collet block shouldn't I then just be able to find the center of the block thus putting me on the center of the rod or pretty close. I know this all depends how accurate the collet and block are but am I thinking correctly or am I off ???? I just need to drill a cross hole a bolt will go in to hold a rod in a plasma cutter circle cutter so it doesn't need to be NASA accurate lol
