- Feb 12, 2023
- 27
It was raining here today so I took the afternoon to put the kit together. The instructions are excellent. About all that I saw missing was the picture of how to wrap wire around the lead bending gauge to make jumpers. If you need a picture for that you might want to reconsider hobbies. At over 55 years of making solder smoke this is the first kit I have ever had that included a tool for bending the component leads to the correct length. A very nice touch. Using different color resistors was nice touch too. At this stage of life reading color codes means good lighting and a magnifier. The last few kits I have built were surface mount so the through hole on this one was a breeze.
I paired the ESP32 before starting to solder things together just to check it. Took some digging to find the pairing password but I found it.
I am using the Vevor scales ($116 got me 150, 200 and 600 mm scales) and just followed the diagram in the box for connections.
First attempt to check the scales was a big fail. The micro usb connector fell off the ESP32 when I plugged in the cable. It doesn't look like there was any solder on the mounting tabs for the connector. I scrounged an old USB A/B printer cable out of the junk box and cut the square end off of it. That gave me a nice long power cord and I clip leaded that to the power connections for one of the scales. If I have to flash the chip for a new version I will either replace the ESP32 or solder on a new micro usb connector. I probably have a barrel connector I can use for a power connector.
Using 5080 as a calibration number gets me very close to the correct measurements using a ruler. All three scales work. I didn't bother to check the Y/Z/W axis but I am pretty confident that they will work. If not there is an old Tektronix scope on the shelf and I made my living for a few years troubleshooting digital stuff with a scope at NCR in Ithaca NY.
Next step is to get the scales on the mill and 3d print a case for the board.
Yuri - you did a great job on this.
