Hello, it’s been a minute since I’ve posted, I’ve been busy with work but I’m wanting to get back on my lathe. I had a few problems with my grizzly so I’m working on getting it dialed before starting on a few projects. I swapped the compound clamp for a more rigid 6 bolt one that helped, and I got an er40 chuck & backplate. I’m concerned about the backplate though because the 3 & 4 jaw chucks that came with the lathe have 2 little clamps that screw on to the backplate, clamping on the spindle to get a better attachment than just using the spindle thread alone. The er40 backplate doesn’t have the extra collar extending past the treads (where the little clamps screw in). I also have to worry about machining the backplate,
but I’m asking if I can use this with just the spindle thread or if I need to get a new backplate. My other problem I need to fix is what my lathe is mounted on. Right now my lathe is on a harbor freight tool cabinet (on roller wheels) and I want to find a more solid solution so I don’t have any lathe twist and that way I can level the lathe if I need to. Any insight & advice on the chuck or my lathe stand would be greatly appreciated, Thanks!
