- Sep 11, 2015
- 293
Long story short, I ended up with a stripped female thread and need advise. I'm in the middle or reassembling an atv motor. While putting the wet clutch housing back on, I stripped a single female thread in the right crankcase. It is not a bolt that holds the left and right cases together, but simply holds a wet clutch housing cover.
The bolt was to be torqued to 7 ft lbs. I began torquing procedure by going around all the bolts on the cover in a criss cross pattern and incrementally tightening to avoid warping and what not. Well it stripped before the torque wrench would click on the last pass. The others torqued just fine.
My question comes to a few options, I just don't know which one I should do. I can helicoil or time-sert, drill and retap for the next size bolt up, or do my own threaded insert (which would invlove using my lathe, hence why I post this in this forum). If I were to make and press in my own threaded insert, how would I go about it? The stripped threads are in aluminum and I'm limited to how much bigger I can make the hole. What does the hive say?
