- Jan 16, 2013
- 34
Can anyone help Mr Cheap here acquire or make gears for a small Lathe?
Looking at a nice 1952 Logan 11 X 36 model 922 lathe. Good ways and headstock. Trashed gears in the quick change box. E-Bay has a QC box, but no gears. Any advice RE repairing gears on a small lathe and a Logan specifically??.
I think Logan used the same QC box/gears in 11, 12,14 inch lathes in this era, maybe 10"s also. So might I get gears from an otherwise worn out machine? Any chance if/when I get it apart I can fit off the shelf gears from Boston Gear or whomever to this machine??
Having new gears made is probably out of the question; my old American lathe thing is an affliction, but not yet a financially fatal disease!! That said, if someone has input that laser or plasma or whatever cutting of small (1"-3" OD) gears could restore this lathe to cut decent threads for "reasonable price" pls advise. Likewise if you think Mr Cheap/Novice could actually do it with his worn 10" Sheldon lathe and sound Gorton 1-22 MetalMaster (Bridgeport size) vertical mill).
Thanks for any/all advice!! Chuck Forman
