- Oct 4, 2011
- 727
I am having problems figuring out the feed rate for a cnc mill. Any help would be great.
Starting with RPM. I am using the formula RPM = Feet per Minute/Pi*cutter diameter
So for a .500 carbide 4 flute mill cutting Aluminum Using a FPM of 900
That gives 573 = 900/3.14*.500
So 573 RPM
Then for feed I am using Feed rate in Inches Per Minute(IPM)= RPM x number of cutting edges x chip load
Using a chip load of .004" I took that value from http://www.endmill.com/pages/training/Speed and Feed - Carbide End Mills and Drills.pdf
That gives 9.1 = 573 x 4 x .004
9.1 IPM can not be right can it? Where am I going wrong?
So 573 RPM
