- Feb 15, 2024
- 71
I'm sure I'm far from the only one who watched Stefan Gotteswinter on YT. I just finished watching his latest video, which all about cutting radii on a manual mill using the DRO, using a technique called Kellering. I think this could be a super useful addition to the TouchDRO toolbox, sometime in the future.
I know that one can use the bolt hole circle function for this, which he does show... It's particularly useful for cutting curved slots, where the tool centerline is coincident with the centerline of the arc.
However, I think the radius milling function he demonstrates is more suited to external radii, than the bolt hole circle function. Because the tool centerline is no longer coincident with the centerline of the arc, the bolt hole circle method requires you to account for the radius of the tool. The dedicated radius function accounts for this inherently, which mitigates one possible avenue of error. Second, it provides the ability to machine a radius in the XZ plane using a ball endmill, whereas the bolt hole circle function only works in XY.
That second ability is what prompted me to suggest this here. That, and It could also be useful in the lathe configuration, for radius/ball turning using a round-nosed tool.
Further, it could also have an "slope function", to be able to cut angled straight surfaces... In XY with a standard endmill, or in XZ with a ball endmill (or XZ on a lathe, with a round-nosed tool)
Anyway, saw the video, and was inspired to post.
