I know hot rolled steel rod is not the best metal. But I'm making a couple of parts with it and my trouble is getting a good finish. I'm trying to face it and end up with a decent finish. My question is would anyone recommend higher speeds for a better finish, deeper or lighter cuts. I've read both versions and not sure which way to proceed. I'm cutting 1" diameter rod, Hot rolled steel, using HSS cutter. I know the quality of the steel is a big factor, but trying to get it looking decent. Thanks for any suggestions.
