Hi all....being fairly new at machining I come to you seeking knowledge from all who have been at this for way longer than I. I wanted to turn a 6 -1/2" long x 1- 1/2" piece of 1045 between centers, but got terrible chatter. I was using a lathe dog and placed a counterweight on the faceplate.....didn't help. Tried different speeds and different tools (HSS & inserts) still didn't help. Then I chucked it up in the 4-jaw, dialed it in, and used a live center and still no improvement (tried different speeds and tools as before ). I finally put the 3-jaw back on the machine with the live center and finally, after trying an insert that is for aluminum I got a chatter free cut (although I think the finish could be a little better).
My question is this: In situations like this is there some trick to getting no chatter or is it just a trial and error type of thing. I just found it unbelievable that I was getting chatter on a 6 1/2" long work piece. I didn't think that was too long or so long that I would get chatter the way I did. Any advice you all could give me would be greatly appreciated. Thanks
