- Dec 17, 2012
- 630
I had a little drill chuck I had bought to play with an old Emco lathe. Well, I didn't really have anything to do with the lathe any more so I decided to use the chuck on my lathe. It has and M14x1.0 thread and my lathe has an MT2 tailstock. Perfect chance to make my first MT2 taper.
I set the compound to the MT2 angle by putting an MT2 arbor in the chuck and running up and down on the taper with a dial gauge until I got it to zero for the length of the taper. Then I turned the taper on some 12L14 and began the wait. I had no way to hold it to turn the other end. I ordered a MT3-MT2 adapter and when it got here tonight, I took off the chuck and put the arbor in the the headstock to turn.
Turned it to just under 14mm and then threaded it with a die. I had to do a little tuning with a file as I didn't get the angle perfect on the taper. Once I did a little fitting and tuning, it seated nicely. Only thing I forgot to turn a chamfer on the end of the taper. Well, I will on the next one.
Half inch chuck for comparison.
