- Mar 31, 2023
- 17
Hi i have a 8 mm hex broach with a stated max cut length of 25 mm and would like to extend it to 35 mm. My guess is that the max cut length is based on the chips packing in the grooves of the broach. And i was thinking that i can reduce the amount of chips by pre drilling 6 small holes by the corners before drilling the center hole like this:
Would this work to extend the cut length of the broach? And would the 2.5 mm drilled holes be accurate for a 35 mm length when using a center drill first to accurately start the hole?
And no i don't have access to a EDM machine, and don't want to pay a lot of money for a company to wire-EDM this part.
