Extended Jet Lathe Back Splash
Bib Overalls
Dec 13, 2015
17
Several months ago I spotted some neat brackets on eBay that facilitated hanging Aloris type tool holders on a flat vertical surface. They were cheap so I bought some for the Aloris tool holders I use with my Jet 1040 lathe.
Once I had them in hand the question became "were to I put these gizmos?" My answer was a 1 foot tall extension to the factory back splash. I bent it up out of 16 gauge because it was available and free but 18 gauge should be fine. I had originally planed on making the braces at the end out of sheet metal but when I tried I couldn't make the necessary bends with the break I was using so I made then out of 1" square tubing and 1" angle iron. In the process I got a couple of near at hand places to store my chuck wrench and dial calipers.
The back splash was painted with Rustolium Canvas White. I got quart can from Home Depot. It was a special order. You can also order it in spray cans.
Also note the simple bracket I made out of a stainless steel scrap for the tail stock accessories.
I like that. Especially the reflection on the tailstock tools that makes it look like there are twice as many.
Very nice job, looks like a special order accessory. Great to have a brake when needed. Storage is always premium in a shop even a home hobby. YUPP you did great , bet others may want one.
Nice. Can you share the eBay link for the brackets?
